Welcome Guest - Sign Up today
No announcement yet.
primer bulb location?
  • primer bulb location?
    Where should the primer bulb be located in fuel line in reguard to gas filter?
    Re: primer bulb location?
    It is presumed that you fuel filter you speak of is mounted in the boat. The primer ball can be located on either side. Makes no difference to the motor. I like it before the filter. Between the tank and the filter. Makes it much easier to refill the filter when a new filter element is installed.
    • #3
      Be sure to install the primer bulb with the arrow pointing up.
      • #4
        Be sure to install the primer bulb with the arrow pointing towards the engine.
        just because you found it that way does not mean it is supposed to be that way.
