can anybody help?1: we have a suzuki dt 115 2 stroke had it out other day fishing when start engine to move it started fine put it in gear to move and it would stall before i could get revs high enough to move. if you move the lever quick enough it was ok but passengers had to hold on. I turned the idle switch up 1 click and it solved the problem but is now idling at 1000rpm is this ok?
2:Water light was coming on with the alarm as well when started pretty sure its the temp sensor have tried to take sensor out but have broken it off in the housing now having trouble removing rest of it, any ideas would be greatfully recieved
engine had service including carbs and water pump
