maineiac5586
- Feb 14, 2009
- 644
Hi, I have a 1985 Yamaha 115 ETLK and I need a new sub oil tank. The original part number is 6E5-21708-05-00
I found a new tank with a different part number that looks identical except the wiring connector is a newer style using a blue plastic connector. Mine uses a white connector, the pump has bullet connectors so I guess I can use my original wiring, can I cut and splice the wires coming from the sensor (it is new and in the new tank), to my original harness? Someone been through this before? please help, thanks
