BigBand
- Jun 2, 2002
- 17
OK - newbie here! I searched this forum for advice, and I'm getting conflicting info.
I'm chasing down a cooling problem with this 1989 Yamaha 15LF. No water stream when I start it up. Starts great!, just no tell tale water.
First question - shouldn't the stream appear within a few seconds of starting? I'm assuming the tell tale is on the supply side of the thermostat, and would be visible with the thermostat either open or closed..
Second - Do Yamaha gaskets of this vintage need sealer or not. I'm talking the thermostat gasket as well as the head gasket.
Third - Are gaskets even needed in these two locations? Wouldn't RTV silicone work on the thermostat housing?
