I don't have any compression in #2 cylinder. I had a couple of boat repair guys stop by and one thinks it is a broken piston rod and the other thinks it is a broken piston ring. I've never rebuilt an engine before, but if it is a rod or ring, could this be a job I could do, or does it take special tools? I don't think the head is warped or something else caused by heat. The engine looks OK from the outside (no residue or heat indications on the head).
Would I need to take the motor off the boat, or could I do the job with the motor mounted?
Thanks,
Andrew
Thanks,
Andrew
