Welcome Guest - Sign Up today
No announcement yet.
1990 yamaha
  • 1990 yamaha
    my motor drags then turns over after a few seconds what is the problem
    Re: 1990 yamaha
    Your not holding you tongue properly
    should be sticking out the left corner on your mouth while turning the motor over
    Ok back to the problem
    Bad battery, battery cables, battery cable connections are the most often problems.
    Then bad starter, motor binding up, or lower unit binding up
    Does it start up, but just turns over slowly at first?
    If so, my guess is battery or connections
