glennbridge
- Jul 17, 2012
- 1
is the handle on a 703 yamaha remote control reversable , it looks like it is ,
Well, I stand corrected, but reversing would look like a job for a real pro...I wouldn't try it!
Remove center bolt and switch to the other side. Very simple
The only problem is the t&t will reverse sides too but I guess you can get used to it. Are you running a center console?
You seem to be wanting to create a problem where there normally isn't one.
The OP asked if the handle was reversible, and it is. So what is the problem?
