Welcome Guest - Sign Up today
No announcement yet.
1990 250hp yamaha 2stroke fuel / pump trouble shooting help please
  • 1990 250hp yamaha 2stroke fuel / pump trouble shooting help please
    Re: 1990 250hp yamaha 2stroke fuel / pump trouble shooting help please
    Well my motor doesn't have an electric fuel pump, but had recently faced similar issues with air leaks and bad fuel.
    Here's what I would do:
    1. Isolate that the fuel delivery is on the motor side by hooking up to an external tank (with fresh fuel!!!).
    2. If problem is motor side, get a pressure/vacuum gauge and rig it up after the primer bulb. There is a good tutorial on testing the fuel system somewhere around here. Try the FAQ section.
    3. I would definitely add zip ties.
    4. How would oil injection be relevant? To test, prevent the reservoir from refilling automatically. Put a mark on that tank and run it for a little bit. See if the oil level decreases.
    HTH
    • #3
      The answer turned out I needed a much larger battery, Napa with 1000cca was all it took. (I was using 750cca)
