Remote reservoir is full. Line not pinched. Batteries are good. With ignition on, emergency switch on engine's reservoir does not respond. Engine reservoir is half full. Suggestions?
Re: 1988 Yamaha 130 ETXG - Remote oil reservoir not delivering to engine
check to see if you have lost 12v to oil pump, e switch controls the ground I believe.
do a forum search for no oil transfer, it has been covered many times
