ZX10R
- Apr 30, 2012
- 12
Hi Guys and Gals new member here,
My boat and outboard are 22 years old so I decided to replace some things. I put on a new water pump, new fuel pump, and carberator rebuild kit. The outboard starts fine, idles fine, if you ease into the throttle during take off that seems fine. I am having a problem with when you punch it the motor boggs down. If I am in gear and punch it the motor boggs down real bad then takes off or if I am cruising at 3500 rpm then go to full throttle it starts cutting in and out.
I replaced the floats, gaskets, and air screw in the kit. I measured the air screws and set them right back to the same setting. The floats in the bowls I can not find any info out there on how to set those so thinking that might be the problem not really sure. Can someone help me on this?
Sean
Sean
