Re: 2004 yamaha 150 hp 2 stroke
first, i would assume it is a carb issue, spray some fuel in carb throat that is dry, first try idle, then try at speed(needs 2 people), that should determine whether you need to take off carbs and clean, remember you must remove airbox first, good luck let us know what happened
