Welcome Guest - Sign Up today
No announcement yet.
2004 yamaha 150 hp 2 stroke
  • 2004 yamaha 150 hp 2 stroke
    1 of the six spark plugs is completely dry and the engine will not exceed 30 mph!!
    Re: 2004 yamaha 150 hp 2 stroke
    first, i would assume it is a carb issue, spray some fuel in carb throat that is dry, first try idle, then try at speed(needs 2 people), that should determine whether you need to take off carbs and clean, remember you must remove airbox first, good luck let us know what happened
    • #3
      take your carbs off and clean them real good, a soak in laquer thinner will get unseen passages.
      Free ignition troubleshooting guide http://www.cdielectronics.com/techni...ort-documents/
      You will need a DVA adapter http://www.usatoolwarehouse.com/usat...e/ESI-640.html First test compression, Second test spark with a spark gap tester set a 7/16 gap, Third check timing, next CLEAN your carbs properly,
