Hi,
Sea water was mixing with engine oil.
Cylinder-head has cracks on the surface mating with the top of the block (which has no scatch).
Craks are only arround the area that face the two bottom cylinders (sea pics).
Any idea of the cause ?
Some friend says it could be sea water coming up through open exhaust valves (which apparently occurs on low mounted engines). But I'm sceptical : no damage on the cylinder walls or piston heads.
Is it worth replacing the cylinder head ($1600 bare) ?
Thanks
Here is some history about the engine that may help :
- 30 hours only, but stood still for 8 months, laid on one side with oil in. Pistons stuck when I got it ;
- removed power-head and cylinder-head. Found oil had made its way into the two bottom cylinders and had turned like varnish ;
- cleaned and freed pistons. Noticed craks on the cylinder head but not bits of metal in the cylinders or in engine oil. No scratch on the cylinder walls ;
- hooked everything back up with new gaskets ;
- Engine ran fine for 5 hours (checked oil every 30 mn). Then noticed sea water was mixing with engine oil.
Thanks
