2007 yamaha 90 4st wiring harness
Ken Pettman
Require the main harness for 2007 90 hp 4 st. believe the 115hp the same. Only require the injector fittings with short pigtail if someone has a damaged harness. I don't know what year injector plugs will fit. Thanks Ken
rodbolt
Re: 2007 yamaha 90 4st wiring harness
how many do you need?
I may have a few.
ill check over the weekend to see what fits the efi 90.
only way its avalible from yamaha is a complete harness.
Ken Pettman
Hi, I require 2, would certainly be appreciated as I'm trying to get this motor going again. Please advise when able. Many thanks in advance Ken
rodbolt
whats wrong with your connectors?
Ken Pettman
Hi, Unfortunately some one tried to steal the motor, and when unsuccesful they cut / yanked the wires off the two lower injector plugs and the fuel filter sender. If the little spade connectors were still there I could probably splice in new wire but a few of them were torn out and have disappeared.
That is why I think if I could get two plugs with about a 3inch pigtail I could splice them into the existing harness . Thanks Ken
rodbolt
ill try to see what else fits the F90 injector.
rodbolt
i have a set from an F250, look similar.
gotta find an inline F motor to see if its the same.
Ken Pettman
Hi Rodbolt, Any luck with the fuel injector plastic connectors (pigtails) for a 2007 F90 or a complete harness ?
