Welcome Guest - Sign Up today
No announcement yet.
1990 Suzuki DT30 wiring
  • 1990 Suzuki DT30 wiring
    hi, finally identified my oil injection DT 30 to be a 1990 model, so now i need your advice and help, the previous owner had problems with the control box switches etc so cut off the loom at the control box end leaving the flying lead from the engine about 12 foot, please identify and confirm what each wire does
    White
    Grey
    Black
    Blue
    Brown
    Green
    Orange
    Yellow
    Pink
    Light Blue
    the last two (pink and Light blue) end with a bullet fixing
    All help really appreciated as i will have to make a control panel up to use the engine.
    Bitsa (5.4 m Avon Searider) with Chrysler 85 hp Charger, Seetanzer (4 m Avon Searider) with Chrysler 45 hp , Maxum 1900 sc with Mercruiser 3.0 A1 G2 drive
    Re: 1990 Suzuki DT30 wiring
    Here's what I have according to my suzuki wire color code chart
    white=+12 power constant
    grey= +12 power switched from ignition
    black= ground
    blue, green, red = stop engine
    brown= start
    orange= choke
    yellow= tach signal
    pink=trim down
    light blue=trim up
    • #3
      That is correct. If you wanna get more details, see http://switchbait.com/forums/showthr...=wiring+colors
      --- Complex problems may have simple solutions ---
      sigpic
      -------- Simple problems may be hard to fix ---------
