Welcome Guest - Sign Up today
No announcement yet.
2004 yamaha 4 stroke 150 hp
  • 2004 yamaha 4 stroke 150 hp
    My engine has started smoking at idle and excess fuel is dumping out the exhaust. I removed the spark plugs after running at idle for a few minutes and #4 spark plug is wet with fuel. Engine seems to be running smooth maybe a little rougher than normal...
    Any ideas what might be causing this problem?
    Thanks
    Re: 2004 yamaha 4 stroke 150 hp
    Have you checked for fire on the #4 spark plug??
    • #3
      I have fire. I wonder if it could be the vapor recovery causing the excess fuel being released in the exhaust?
      • #4
        most likly an injector leaking,a VST needle valve leaking or a bad pressure regulator.
        vapor canister wont have anything to do with raw fuel in a cylinder.
        no tech questions by PM, they wont get answered.
        you have to be trusted by the people that you lie to .
        • #5
          Thanks. I'm taking to the dealer.
