vbmlows
- Oct 5, 2009
- 13
Rodbolt,
You had mentioned cleaning fuel lines in another post to prevent carb fouling. How would you do that and what would you use? And how do you know if the fuel lines are clean enough?
Is it OK to use carb cleaners to clean fuel lines by letting it sit for an hour or so in the stuff and then flushing out with gasoline to make sure you don't accidentally try to run the engines on carb cleaner?
