Re: high speed stall out
Sounds like you are running out of fuel. Try squeezing the bulb when wot and see if it helps. If it does you may have a bad fuel pump. It sounds more like you need to pull the carbs off and clean them. Check your compression and make sure all is good there. Are the plugs new?
