My 2000 50hp Yamaha has been hard to start unless choke linkage is manually put in closed position. I continuity checked the ignition switch per manual and all positions read correctly. The choke solenoid is the next suspect, but there is also a "thermo switch" on a blue wire down stream of the solenoid. Does anyone know where that is located?
Ebraker
Ebraker
