Suzuki DT100 Carb Adjustment
beau v
The plugs on my DT100 appear to be wet and the engine stalls out when I increase trottle from idle. Can anyone give me some advice on fuel mixture?
This is a '96 Suzuki DT100.
Thanks in advance.
beau v
Re: Suzuki DT100 Carb Adjustment
As an addendum to above I figured out that the problem was the valve starter. Opened it up and it looked like a mud puddle in the bowl and had more corrosion than I have ever seen on any outboard motor part. Cleaned it well and it seems to have fixed the problem.
Now, does anyone know what the valve starter does???? Assuming it is an enricher of sorts.
Also, does anyone know what the proper adjustment is on it??
Any information would be appreciated.
