Re: 05 115 Yamaha Tilt Trim malfunction
Dougalass,
A good simple way of isolating the problem is to remove the blue (up) and green (down) wiring connections from the trim motor where they connect on the relay. Use a couple of jumper wires to manually connect the leads to the battery. When blue is connected to positive, and green is connected to negative the motor should trim up. Reverse these connections and the motor should go down. If nothing happens then the motor is bad.
If you find that the motor is good, then the most likely culprit is either the relay or the switch. Use a test light to check that your getting power and ground at the right places. When you trim up the blue wire should have 12V, the green wire should have connection to ground. When you trim down the reverse happens, green is 12V, blue is ground.
You can confirm the problem by using the part from your port engine. If the problem follows then you found the issue. If it didn't follow then you need to look a little further.
