Oil leaking out of carbs I think
I have a oil injected 150 Yamaha . When I park it and tilt the motor up I get drops of blue 2cycle motor oil that drips into the transom. Is this a sign of a problem. Also does it really matter what two cycle motor oil you use?
cousinabe
Re: Oil leaking out of carbs I think
post the full model number off the port side bracket.
need to know what we are dealing with as they are different.
robert graham
I get some outboard oil in my intake airbox. when I remove it, some just pours/drips out. No problem so far. My motor is a premix model and I think some fuel gets in there and evaporates, leaving behind the oil. Good Luck!
robert graham
On the subject of oils, For years I always used Yamalube with no problems at all, switched to Pennzoil 100% Synthetic Outboard Motor Oil(Walmart $27/gal.) a few years ago , still no problems but cleaner, less smoke, less carbon. Plenty of opinions on oils/lubricants. Highly recommend Stabil Marine and a fuel/water seperator. Good Luck!
