I'm working ona 9.9 Yamaha that I acquired froma friend who had been plagued by an intermittent problem with engine stalling and not coming up to full rpms. After three trips to the authorized dealers, who repeatedly cleaned his carb and check book, he rebuilt the carb then the fuel pump and then gave up and bought a new one. After following a couple threads on this forum I'm starting to think it's the oil pressure switch so I'll ask a couple questions. First, the oil pressure switch is a normally closed switch wich grounds out the indicator light. The Clymer manual says that it should be closed from 0-1.4psi and open from 7.1-9.9psi. What happened to the 5.7psi in between? If we're talking about variations of less than 2 psi a lot can happen in almost 6 psi. Second, assuming this is the problem, what happens in the CDI when the link to the light, through the switch, is grounded? And is that a cause for the engine to refuse to come up to speed?
FYI The engine will run at it's lower speed for an unpredictable time and just die. It will immediately start again and run smoothly at it's reduced speed until it does it again.
PS The Clymer manual is pain in the exhaust manifold!
Scotty
Scotty
