Welcome Guest - Sign Up today
Announcement
Collapse
No announcement yet.
Throttle handle problem on Suzuki DT 6
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • camarasm
    started a topic Throttle handle problem on Suzuki DT 6
    I have a Suzuki DT 6. It runs fine, but unless pressure is kept on the handle throttle, the handle rotates back to slow idle (on it's own). The manual indicates that there is a throttle tension knob at the end of the handle (at the aft end) but I can't seem to find it or figure out how to adjust the handle so it will remain at speed setting when the throttle handle is released. Any information would be received gratefully.
    Thanks!!
  • sasmit8
    replied
    Re: Throttle handle problem on Suzuki DT 6
    I have a Susuki DT6 (1998) the knob to tighten the throttle is on the side of the tiller back toward the motor(large round twist knob). On some of the newer ones (92 -02)it looks like it is on the under side of the tiller.I found this by looking at the parts break down at www.brownspointmarine.com Hope this helps
    Leave a comment:
Working...
X
