Welcome Guest - Sign Up today
No announcement yet.
1991 Suzuki DT115 crack in lower unit
  • 1991 Suzuki DT115 crack in lower unit
    I just got a 1991 Suzuki DT115 and 91 sportcraft at a great price recently, now I know why!!! took it out, ran great. Was just looking at the lower unit today and and noticed two small cracks (1 inch and 1.5 inch maybee) right behind the prop. No oil has leaked out of them, and based on the existing corrosion looks like they've been there a while. The cracked area is slightly separated, Is this the exaust portion and not a big deal? I was getting ready to sand the whole lower unit and zinc chromate then paint it but not wondering if i need a new lower unit? I want to put pictures in here but I can't... won't let me add any...
    Can someone tell me how to post a picture?
    Re: 1991 Suzuki DT115 crack in lower unit
    that crack is normal salt water corrosion.
    it happens.
    drill a 1/8" hole at the end of the cracks and have it welded.
    then go play knowing one day the case will fail.
    may be tomorrow, may be 10 years.
    you wont strike oil for another 3 inches or so.
    no tech questions by PM, they wont get answered.
    you have to be trusted by the people that you lie to .
    • #3
      P.S. I don't think the cracks extend beyond the prop shaft housing o-ring in the back.
      • #4
        LOL that was quick, thanks, didn't see Your reply before I reposted. So, if and WHEN it does fail, is it going to toast my engine or just break some gears and I buy a rebuilt lower?
        • #5
          Found out how to post pics, this is what i'm talking about specifically. Still just weld you think? Do you think Marine Tex would work for this? If water gets into those cracks, couldn't it corrode the prop shaft bearing housing? Or does that get wet anyway and I need to worry more about the structural integrity of the lower unit? Thanks!
          • #6
            Follow Rodbolts advice and you will be fine.
            If you are really gung-ho you can remove the prop shaft housing (boy that's a fun job), clean all of the corrosion as best you can, paint it, and slather the shaft housing to lower unit housing interface with anti-seize (never use the copper one). That should give you 10+ years easy.
            '96 Hewes Red Fisher '97 Suzuki DT140 EFI
            • #7
              Went and got it welded and painted, worked out great, thanks!
              • #8
                I dont know where you live but i have 2-1991 suzuki dt 115 motors for parts. Everything, contorls, props, everything.
