Welcome Guest - Sign Up today
Announcement
Collapse
No announcement yet.
suzuki dt30 wiring harness
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • gamekeepa
    started a topic suzuki dt30 wiring harness
    I have a 1986 suzuki d30.Is it possible to wire it up to a key ignition from a car or do you have to have the correct suzuki switch?The wire harness coming from the engine has 7 pins.Can i cut this off and just wire straight to an ignition?If so how do i do this?
    Thanks
  • Yepblaze
    replied
    Re: suzuki dt30 wiring harness
    You would have to check the schematic diagram for your motor.
    Some motors use power for the ignition and some ground a wire to kill the spark.
    It's possible to do expensive damage if not dealt with correctly.
    Leave a comment:
  • predator165
    replied
    hi i seen your post on wsf and thought to spent some time searching iboats , and here i see your listing also lololol
    sorry to say that i havent been able to find anything sofar
    ron ( irishron40 on wsf)
    goodluck
    Leave a comment:
  • James R
    replied
    The harness carries the main power + and -, the buzzer warning signal, the ingnition on/off and the choke. Every thing is possible but what a messy job. Automotive components are not suitable for marine applications.
    I know the Suzuki replacement is not cheap but that is the only way to go.
    Leave a comment:
  • phwrd
    replied
    Welcome. . .
    what type key switch do you have now ? Turn to start or push to choke & turn to start ?
    Are the wires on your current swith attached to a harness, battery or wire nuts ?
    Wouldn't use a car part ever on a boat...different type wire. Car parts don't weather well.
    Hope that helps.
    Leave a comment:
Working...
X
