Can I use a flow meter on the intake side to sync the Carbs on 1983 DT50
sturdavj
Can I use a flow meter on the intake side to sync the Carburetors on 1983 DT50?
The manual shows using the manifold connecting hose between one & two as the point in which to measure the vacuum difference.
Manual uses a four-tube/channel device with four connecting hoses. As far as I can tell only two are used on the DT 50.
Does anyone know where I might find one of these critters?
The flow meters I have been able to locate so far measure on air cleaner/intake side of the crabs.
sturdavj
Re: Can I use a flow meter on the intake side to sync the Carbs on 1983 DT50
bump
