8hp suzuki dt8c kicker motor oil injection removal
v20belowme
I have an 8 hp suzuki dt8c that I am going to use as a kicker motor on my wellcraft v20 fisherman.HOw would I go about removing the oil injection on it so I can run if if i need to off of the boats tank which is premixed.remove tank and hoses and cap off hoses.Do i have to do anything with the level sender wire??what is the ratio of fuel to oil mix on this motor.thanks-doug
deejaycee_2000
Re: 8hp suzuki dt8c kicker motor oil injection removal
the motor runs at 50:1 oil, fuel mixture, all you need to do is take the oil pump off and take out the little drive shaft of the oil pump that makes it pump, put it back together, it is the best and easiest way as the pump will just not be pumping, then run with the pre-mix, if you really feel like taking the oil tank out you can plug the pipe from the oil tank into the oil pump, the other hoses you can leave as is ........
