Hi, I purchased a 1988 deck boat with a Suzuki DT 65 <br />outboard, the guy I bought it from said it ran when it was parked, not sure if he was telling the truth?<br />I put new fuel lines and fuel, cleaned and put new oil in the oil tank, cleaned all wire connections to the battery.<br />I went to start it and as soon as I hit the starter switch a beeping noise started, It cranks but there is no fire, there is a reset button on the side of the engine that says (low oil reset) I have tried that but with no help, there is a float in the oil tank that I pulled out and moved the slidding float up and down and the beeping would stop, but as soon as I cranked the engine the beeping would start, and still no fire, Is there a safety shut off on this engine. can anyone tell me where to start checking, This is my first Suzuki outboard, <br />Thank you.
