tjthomas25
- Jul 18, 2005
- 15
I've got a 89 Suzuki 75 hp outboard with a inline 3 cylinder and when i got back from the lake i check the spark plugs to see if they were all in good shape and if all the cylinders were working, upon looking at the 1st and 2nd cylinders it was fine then i took out the third one and it was clean didnt have but a little bit of oil and gas on it. The motor had been setting since 1991 when i bought it and had only a few hours on it and replace the spark plugs and but gas in the gas tank started right up sounded fine then when we got to the lake it ran a little odd and was slow and wouldnt let the boat plane off, probably becuase the i couldnt use the t/t becuase of the person at a marina sent me the wrong control box and now cant be reached so i had to buy another one which is on the way. Any ideas what might be wrong with it? Also I need to know how to put the t/t fluid in the motor.<br /><br />Thanks, <br /> TJ Thomas
