Welcome Guest - Sign Up today
No announcement yet.
Suzuki 16hp outboard reverse cutoff?
  • Suzuki 16hp outboard reverse cutoff?
    Just purchased a new boat and it has a 16hp suzuki outboard on it. The previous owner said to be careful because if you start it in reverse it will knock you on your ars. He said that he tried to order the part but its not being made anymore....Any suggestions? The motor is an 83?..and getting knocked down while starting dosen't sound fun.....Thanks in advance for any suggestions.....Warren
    Re: Suzuki 16hp outboard reverse cutoff?
    Well, my firs suggestion is do not start it in reverse............but that is because you did not state what part was bad. If you are looking for a shifter and that is is stuck, then I may have access to some parts. Please add to your post.
    • #3
      thom, thanks for the reply. I just purchased the boat a couple of days ago and i'm lookin into it. I did start it in the can and it runs great. The shift lever is fine so I would think its something else. Don't know much about these suzuki outboards, i'll find out what it is for sure and get back.....Warren
      • #4
        Just found out its the Neutral Lockout on the motor. Is this part available?
