Suzuki DT65 head bolt torque settings
Jon Sharp
Can any body tell me what the torque settings for the cylinder head bolts on a 1982 Suzuki DT 65, serial # 6501 205200 should be? <br />--------------------------------------------------------------------------------
prawns
Re: Suzuki DT65 head bolt torque settings
jon this is what appears in the manual.Cylinder Head Bolts. DT50/DT140 6mm bolts 6/8.5 ft.lb 10mmbolts 29/43.5 ft.lb metric 6mm bolts 8/12N.m 10mm bolts 40/60N.m I hope this helps,Phil
