Upon cruising around the wonderfully markered Tampa Bay, we hit ground several times at night trying to get home. 96 Yamaha 200HP sucked up a lot of silt and was overheating, so we removed and cleaned the intake filters before moving on. Everything was fine for awhile with a great pee stream and then the pee stream stopped yet we did not overheat (no alarming/throttle limiting occured) and water pressure was good. Therefore, I am assuming the watet impeller is still doing its job and only the pee line is clogged. If this is possible, any hints as to how to unclog the pee line?<br /><br />Thanks in advance boards.<br /><br />Jon
