spunkyman
- Jul 17, 2011
- 149
Having an alarm issue with my Dad's boat, a 1990 Yamaha 85hp 2 stroke (model CV85ELD) . Completely rebuilt 3 years ago with powerhead rebuild kit, new impeller, thermo, poppet, s park plugs, shift shaft and control cable. For what ever reason, this guy starts to overheat in the high RPMs (no gauge to tell exactly what RPM). The prop is new, I believe its a 15 pitch. Water pees out the hole as it should. Usually, if I stop, it will cool down a bit after a few mins and I can start to use again at lower rpm once it cools a bit, but I'm not sure what else I can possibly do here. Either, somewhere, the water isn't flowing enough, or maybe a sensor or something?
