2003 Suzuki 225 throttle position sensor problems
wateranchor
The TPS has 4.99 volts when the TPS is unplugged. And theTPS has 3.96 volts when its plugged back up. Could the TPS have a dead short in it that is causing the voltage drop? The motor is acting just like its going into limp mode, but no buzzer sounds.Thanks
