jeffconnell12
- Oct 9, 2011
- 104
Hey guys - i have my lower leg apart as i wanted to inspect the gears and dog clutch.. however i CANNOT get the bearing carrier out as it is completely stuck.. i have broken two tools attempting. I decided to drain the oil and it seems okay so i figured i'd leave it alone for now.
I did notice that when in gear i can spin the prop shaft about an 1/8 of an inch before it actually engages the gear and spins the main shaft going to the engine. Basically i can wiggle the shaft spinning it back and for and here it clinking against the forward gear.
Is this normal?? thanks!
