Prefer not to mess with injectors are delicate and costly items...
Can clean injectors with injector fluid cleaner poured inside tank, follow cleaner and fuel mixing ratio. If iworks good for cars why won't it work same for injected outboards..
The "mechanic in a can" stuff only keeps clean injectors clean..it cannot clean the screens as this is where most of the problems occur. The "can" stuff only cleans deposits but flow and spray pattern can still be off. Send to Tony at above posted site and have them cleaned, balanced and flowed..Your engine will love you for this!!!
