2016 VF250XA VMax SHO leaking oil
Caniac03
My VMax SHO is dripping oil from the skeg. The oil is coming from the water inlet? on the leading edge of the lower unit. The motor has about 35 hrs on it and the upper and lower unit was serviced back in May. No oil leak prior to the last outing and the boat has not been out since the leak was discovered. Thoughts and suggestions are appreciated.
