69 Alumacraft
- Nov 15, 2009
- 173
Hello all,
My 2016 yamaha 300f makes a squealing sound when I raise the motor while underway going over 1000-1500 rpm, no noise when it trim it up while at idle, neutral or when motor is off, no noise when I lower it, no visible leaks, rams are greases on top, zerks have been greased. I never checked trim fluid level b/c it is such a new motor (less then 300 hours). My next move is to check trim level. Has anyone experienced this? Also, how could trim fluid level drop without a leak? I have watched videos of the ram tops and pads lacking grease and that is not the sound. Dealer says it could be trim motor caveating b/c there is air in the system. Motor is under warranty until end of July but service guys said if I bring it in and it is making noise b/c of low trim fluid then it is a maintenance issue and not covered under warranty. Any advice appreciated.
