CHSEdgewater
- May 21, 2019
- 2
I’m looking for help diagnosing this oil pressure issue. If I keep rpms at or under 4400, it runs w no issue. When it’s brought passed that speed It will run for a few minutes until an alarm sounds and a black bar flashes over the oil symbol, and seems to go into safe mode. Simply turning the ignition on and off and the problem seems to go away
I have checked oil oil and it is very clean. Could it be an issue with the oil pressure sending unit, or maybe a oil pressure relief valve?
2003 Yamaha F225 with roughly 900 hours
thanks for any feedback
