on my 90hp 80s model Yamaha I need to switch to 50 to 1 mix, but don't want to undo all the mechanicals. If I simply disengage tthe oiler advance lever that opens up the valve to the inside the cowling oil supply for more oil when throttling up. won't that simply allow the unit to continue to oil at an idle rate, even when running almost always above Idle to WOT?
That way, I am hoping to not have to mechancially remoe the oiler and all that entails,,,just have a bit more oil at times, like at startup with no damage or underoiling possible. Thanks for any input.
BTW, anyone know what these little colored wires with connectors mean inside the cowl that were disconnected when the motor was taten off another boat? Photo attached...thanks
