2003 200HP OX66, SX200TXRB Anode Replacement
Gpag
On this motor the cylinder heads have to be removed to get at the internal anodes. I do most of my own maintenance on the motor but getting at the anodes is not a DIY job, for me anyway. I talked to a local shop and they said they’ve never replaced any. What’s the deal with these anodes? Do people regularly replace them? Has anyone ever replaced them?
scoflaw
Ensign
Doubt it, break a head bolt or 2 and you'll be wishin you never tried. There's an external anode on each head that's under a cover .down low.
Gpag
“Doubt it, break a head bolt or 2 and you'll be wishin you never tried. There's an external anode on each head that's under a cover .down low.”
Really? I see 4 anodes, on the exploded diagrams and they all look tough to get to.
scoflaw
Ensign
Your correct there are 4, all serviceable from the outside . 2 are located below the spark plugs at the bottom of the head. 1 is behind the fuel filter and 1 behind the electrical panel where the T/T relay is. They are under a cover that is held on with a single screw.
Gpag
I do not see any anodes. This is an SX200TXRB engine.
