Hi again everyone...I have a 1994 Yamaha 115hp 2 stroke (C115) powering an 18ft. Ebbtide Dynatrak fish n ski boat. The motor looks, runs and sounds perfectly normal. The only thing that concerned me was that the top speed is 40mph which I thought was kinda slow.. (I used to have a 2000 90hp Johnson that pushed an Astro 17ft fish n ski 47mph at WOT). The prop on the Yamaha is an aluminum 21 pitch which allows it to reach a max of 5500rpm ..which is the max rpms Yamaha recommends. So, I performed a compression test and found the compression on all 4 cylinders to be 92,90,92,89. Isn't this way too low? This is the only comrpession test I've ever done on it. I did warm the engine up for a few minutes before the test and I did use a new but cheap Harbor Freight compression gauge. Thank you for any thoughts or suggestions.
