My 1989 200 Yamaha power trim is not working I can hear a clicking sound when the button is depressed at the relay.My question is should there be continuity between positive and negative leads.According to the manual there should be-I bought 2 used relays as a result and neither one indicates continuity with the ohms meter- either all 3 are bad or I am misguided about the test.Are there any other components I should investigate.With the relay disconnected is there a safe way to directly energize the power trim motor to see if that is working?Thank you Andy
