F40GETL 6CY - working not so well
Garkaliu
Hello people,
I have 2 engines, both from 2013, F40GETL 6CY model.
This days I found 2 bad spark plugs so at one of the engine I changed all of them with DENSO XU22HDR9, spark plugs that are equivalent to the original ones NGK LKR7E.
Last year I changed fuel filters, the injectors working fine but I feel the engine without power like in the photo I attached.
Does is someone familiar with this engine? Where should I check to manage to fix it and working like the other one?
rejesterd
Hello.
If you swap all the spark plugs from one engine to the other, what happens? If the issue has now moved to the other engine, then you have your answer: buy the original plugs.
