Birdblaster
- May 6, 2019
- 2
My 130 died while out on the water, not a huge issue till I tried to restart it nothing zero no power at all not even tilt worked. Got it home and checked all the fuses good. Tracked it down to a grounding issue I believe. I ran a jumper from the negative battery post to the engine and boom everything works. So my issue is I cannot visually see any bad or burnt ground wires. I have checked all ignition in the remote all seem to test good.i did find a pair of ground wires bolted to the trim tilt solenoids, one them the larger tested good the smaller was a blank no idea where it goes to test it. If anyone has any ideas or where I should be looking would be great. I'm tempted to run a new ground straight off the battery just a tad bit nervous doing that. Hope somebody here can help out.
thanks
thanks
