DT140 Prop stuck on not seized but stuck on
fish'n-NV
So I have removed it many times but it is stuck on now. There is play in and out after I remove the cotter pin and castle nut. It is like a spline broke or something and is stuck in there. Need help removing it. Thanks
robert graham
Did you strike an underwater object that may have twisted the splines on the prop shaft and/ or the prop?
fish'n-NV
Not that I can recall. I have spun props and sheered pins on other motors and sheered all the blades (pin failed to sheer) so I am familiar with hitting things haha but no on this.I was going to just remove to check for fishing line on the shaft and found it out. This particular prop is a SS prop that I have spun and had rebuilt so hoping that it should work as intended if I did hit something but I dont remember any events.
