Yamaha ox66 will not idle
Ok fresh rebuild on power head ..comple co fuel system overhaul new lift pumps vst s reencinjectirs serviced everything check fine on electronics ....once motor is run a while it will not idle it chugs and dies and smells very very rich once you fire it up with a little throttle it runs great except trying g to idle
scoflaw
Ensign
Check it with the winky/blinky ? Does it respond to turning up the idle screw ? Has the O2 sensor been cleaned and tested ?
scoflaw
Ensign
could be a failed O2. Inexpensive replacement is ngk/ntk 21006. Sensor needs to be tested at all rpm's in a running engine. Bench testing is useless
