I smashed a rock resulting in chewing up my forward gear and pinion gear during the winter chasing ducks around, after I hit the rock the outboard stopped pumping water out of telltale, it would only come out as a weak stream in neutral and reverse, I have since tore the lower unit apart and replaced all parts that were damaged and while I was in there I replaced the impeller, still no water coming from telltale, but it is pumping out of the exhaust hub, has anyone had this issue and if so what did you guys come up with
