Welcome Guest - Sign Up today
Private Messages
We are aware of a current issue where your messages screen does not properly load and we are working on a fix.
In the interim, you can access you messages by navigating to this link: https://forums.iboats.com/privatemessage/notification
Apologies for the inconvenience.
See more
See less
Normal compression for Mid 80's Suzuki DT 40
  • Normal compression for Mid 80's Suzuki DT 40
    Anyone know this I seem to get around 95 and wonder if this is low?
    i did rebuilt. new oversize piston . i got 150 psi
    normal runing compresion would be from 100-150 psi
    • #3
      Ok, at 95 I might be ok then It is a jet and they are hard on Outboards
      • #4
        How did your rebuilding go...I was going to rebuild this one as they person I got it from cheap said it had low compression. Tested it and it seems ok. Cleaned carb as I thought maybe that was the problem. Did you have to have it bored? Wondering if I do rebuilt if I could get away with new rings.
        • #5
          new oversize piston kit, size +50
          new con rod kits,
          new bearings
          new gasket for the head and water panel on the head
          All parts from Taiwan
          total cost around 300$
          • #6
            NOT BAD !!!! I buy some parts from there also...big wait but worth it. Amazing how cheap 4 stroke carbs like for snowblowers are.
